Read Audit Log and EventLog over API
I need to set up an external REST client to read AuditLog and EventLog over API hopefylly anonymously
Is it possible?
ntripathiAnswer
Greetings @TT_12004561,
I hope this message finds you in good health.
I am writing to inform you that you can read AuditLog and EventLog using the Configuration API Service.
  • Messages from the event log service can be read from a REST client by sending a GET to
  • Event log entries
    https://<hostname>:<port>/config/v1/event_log
  • Audit log entries
https://<hostname>:<port>/config/v1/audit_log
  • Please refer(section "Configuration API Service — Content Retrieval " section ) of this link for more details
Note: Every API call requires authentication; you need to provide credentials each time you start the service.
ntripathi16-PearlAnswer
  • Event log entries
  • Audit log entries
