Oct 28, 2026 1:16 PM UTC
Reading VIN or LTR_VIN in Kepware
Hi ,
I'm using Atlascopco PF6000 controller .connected to Kepware using open protocol .Most of the parameters we are able to read and write .At the moment we are  facing issue with reading serial number of the product as  VIN or LTR_VIN . Barcode scanner is connected to  Atlascopco through USB  .we should  be able to read the serial number after the scanning in VIN or LTR VIN but we are not able to read  it .Could you please let me know the procedure?
Support
Nov 4, 2026 12:39 PM UTC
Greetings!
The VIN/LTR_VIN value is not exposed by Kepware through Open Protocol unless the controller is configured to send the scanned barcode to the VIN field. Please verify in PF6000 that the USB barcode scanner is assigned to VIN/LTR_VIN, confirm the scan is visible on the controller HMI after scanning, and check that the Open Protocol job/subscription being used includes VIN data. If the value is visible on the PF6000 but not in Kepware.
Mohit
