Run app without administrator permissions
Hello Everyone,
We have applied a policy that has removed our administrator permissions.
Its possible to execute the application without admin rights?
Thanks a lot!
I've found the solution :
  • For new installations non-admin users need to be given read and write permissions to KEPServerEX application data folder (default: C:\ProgramData\Kepware\KEPServerEX 6\).
    • Without these permissions they will not be able to launch the Administration or Configuration utilities, nor the runtime service in interactive mode
  • For upgrade installations the installer does not alter permissions
    • by default any standard windows user will continue to be able to use the application
    • the user should refer to the documentation on setting up Active Directory permissions to lock down access to the Application Data folder
regards,
please ask PTC Support.
TimbalerDelBruc1-VisitorAuthorAnswer
regards,
