3-Newcomer
Tag generation problem OPC UA Client
Hello everybody,
I´m struggling an issue with KepserverEX 6.11 and OPC UA client.
I´m trying to add a tag, "ProgramPointer", from ABB IoT Gateway 1.3 and I´m getting this message in the event log: "OPC UA Client ABB_IoT.R21 | UA data type not supported. Tag cannot be imported. | Tag name = 'ns=3;s=2600-11****_2600-11****/RAPID/T_ROB1/ProgramPointer', UA data type node id = 'ns=2;i=15108'".
I´ve tried to connect to the ABB IoT gateway (OPC UA-server) with a couple of other OPC UA clients and they can read the value of the tag without any problems, the value looks like this: {mModulename | Routinename | Rownumber}.
Is it because the value is divided in to three different data that KepserverEx is complaining?
I might add the there isn´t any issues with other tags, just this Programpointer tag.
Regards
rajskumarAnswer
We support the data types listed in our driver manual. I recommend that you check the driver manual to see if the data type you need is supported. If it is not, you can submit an enhancement request.
rajskumar16-PearlAnswer
