Trigger Service off of Kepware Tag Change without Opening Mashup
I have recently been learned how to connect to kepware and pull in kepware tag data into Thingworx. I am wondering if I would be able to call a service based on a kepware tag reading value change without having to have a mashup open on a screen. Essentially, I would like to take advantage of how quickly Thingworx can trigger events without having to worry about hosting a mashup. Is there a piece of Thingworx functionality that I can look into for more detail about the possibilities of doing this?
PaiChungAnswer
22-Sapphire I
After you bind kepware tags to a Thingworx RemoteThing Property Thingworx, you can use the DataChange event and Alerts paired with a subscription.
PaiChung22-Sapphire IAnswer
22-Sapphire I
