3-Newcomer
Trying to set up a BACNET Device in Kepware and the Tag Objects are not discoverable
I have setup a BACNET device in Kepware....  How do you make the Tag Objects discoverable when a device tries to connect to the Kepware BacNet device ?
AKsharaAnswer
Hi
Thank you for your query.
Could you please confirm if any specific error message appears when the BACnet/IP device attempts to connect to Kepware?
In the meantime, I recommend reviewing and comparing your BACnet setup with the configuration steps outlined in the BACnet manual to ensure everything is aligned correctly.
Please let us know what you find, and we’ll be happy to assist further.
-Thank You
AKshara14-AlexandriteAnswer
Hi
-Thank You
