U-CON Seek_String hexadecimal
Good evening,
I'm currently working with U-CON (User configurable driver). Telegrams are in hexadecimal. I need to finf a chain of two bytes h90, h90. I can find each byte with "Seek Character" but I have no success by using "Seek String"
Corresponding character of h90 is not available so I cannot use the ASCII character.
I have tried with many format s( ASCII Hex String, Unicode string ..) without success.
Can you please help?
Thank you
Best regards
h90 is not a printable ASCII character, the printable ASCII falls between 0x20 to 0x7E in hexadecimal.
Since, Seek Character works on byte-level searching , might have given a success however Seek String is a text-based searching and as I mentioned earlier h90 is a non-printable byte.
Stephan_G10-MarbleAuthor
Thank you. Indeed h90 (144) is no a printable character but as far I understand from the manual the format "ASCII Hex String" can be used for this case? Do you confirm? If yes, do you know what should be the syntax ?
Sorry, me again. I really need the "Seek String" hunction as I need to find a chain of 2 bytes that can be hA1 h90 or h91 h90 or h90 h90.
From the manual:
Strings encoded as ASCII Hex values.
Example: The string "AB12" would be sent as eight ASCII Hex characters
"AB12" (0x34 0x31 0x34 0x32 0x30 0x31 0x30 0x32).
So I understand that h90 h80 should be encoded by 0x39 0x30 0x39 0x30 . But the format is ASCII Hex
String [hh hh hh...]. So I understand that I should write 39 30 39 30.
I tried but without success
