8-Gravel
Unable to change the Name column in Data logger
In the data logger feature, by default "Name" column is being considered as "Item ID" making difficult in database. How can i change this to "Log item Name" instead of default "Item ID"
Disable the log group
Change as needed in 'Column Mapping'
Enable the log group
8-Gravel
Hey @SlidingDownhill Thanks for response
i am able to change the mappings, but in the place of Name i want Log item name instead of Item ID. So this is my requirement
ItemID is a primary key and must remain unique (no duplicates) to each entry in the SQL database table
I get the idea but I'm not sure exactly what you are asking here:
Can you show a screenshot of the column mapping and the SQL table that results from it. Then show what you want changed.
