Unable to open OPC UA Configuration Manager
Currently using KepServerEx V6 (V6.14.263.0) and unable to open the OPC UA Configuration Manager utility. This is making it difficult to trust new certificates.
Bhupendra
BhupendraAnswer
Hi
Please refer to the following solution article.
Unable to access OPC UA Configuration due to an unknown Administrator password with PTC Kepware Products
https://www.ptc.com/en/support/article/CS386048
Greetings @AF_14035066,
I hope you're doing well.
Please confirm whether you are encountering any errors when attempting to open the OPC UA Configuration Manager.
No errors, icon shows in task bar but nothing opens and task manager shows the app as not responding.
Bhupendra
Bhupendra14-AlexandriteAnswer
Hi
I know the password but receive no prompt to enter it.
Thanks for your confirmation.
Could you please confirm which application shows in the task manager?
I think we need to dig into this issue further. I recommend opening a support ticket with the Kepware Technical Support team for a more in-depth investigation.
You can submit a ticket using the following link:
https://my.kepware.com/s/login/
