8-Gravel
Unable to write values to AWS topic on MQTT protocol
- 1 reply
- 954 views
- Translate All
We have a topic created in AWS environment where we are planning to write values using MQTT client. But the MQTT agent is unable to connect to the topic.
Error : MQTT agent IOT PBM5305 disconnected - reason 'null'
we also referred the PTC article CS378797. But issue is not resolved.
Kindly suggest workaround.
