Variables set to null after certain time Kepserver 6.16.217
I'm coneccting to a sigmatek PLC i'm using KepServerEX 6.16.217. and after a certain time some variable of the project change status to NULL, the only way to connect to them again its restarting all the KEPServer services.
AKsharaAnswer
We highly recommend opening a support ticket with us and attaching the Event Log to it.
Steps for opening a support ticket:  https://www.ptc.com/en/support/article/CS382681
Steps for fetching Event Log: https://www.ptc.com/en/support/article/CS291183
-Thank You
Thank you for your post on the PTC community.
Could you please clarify how frequently the KEPServerEX services need to be restarted? Is it approximately every 2 hours?
-Thank You
PTC Technical Support Team
the first event happened after approximately 2 hours since we started, but then we have another event 30 minutes later, the time its variable
AKshara14-AlexandriteAnswer
-Thank You
pshashipreetham
Hi @MM_13182765 ,
Are you using a trial version of KepServerEx? If yes, then you need to restart the KepServerEx every 2 hours.
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
