Bhupendra
BhupendraAnswer
Hi
  • LinkMaster and RedundancyMaster are no longer supported by PTC Kepware's technical support team
  • Customers can continue using LinkMaster and RedundancyMaster, but Kepware's Technical Support will no longer be available to provide support, including, but not limited to, licensing support and providing executables
  • There will not be a direct replacement for LinkMaster and RedundancyMaster offered by PTC
  • LinkMaster & RedundancyMaster Retirement Letter
  • Note: For any questions you may have regarding an alternative solution or replacement for the LinkMaster and RedundancyMaster
Thnaks
Bhupendra
Bhupendra
Hi
Link master can be downloaded from my Kepware portal https://my.kepware.com/s/
under legacy products ''LinkMaster''
Bhupendra
3-Newcomer
Thanks so much !
Can you tell me what does this mean ?
LinkMaster has been retired as of late 2025. Older versions may still be downloaded for legacy installations.
what is the new 2026 supported version ? Is there something similiar that has support ?
Bhupendra
Bhupendra14-AlexandriteAnswer
Hi
Thnaks
Bhupendra
