where can I find KepserverEx OPC UA client version
Dears,
I am using KEPServerEx 6.9 and version is V6.9.572.0, where can I find the OPC UA client version? I must use up OPC UA 2.0 to connect the equipment
thank you!
cmoreheadAnswer
@CZ_9645217
Please take a look at the following Kepware Knowledge Base article as it may help resolve your issue. The UA Client Driver can be added to the configuration after the original install.
https://www.ptc.com/en/support/article/CS286418
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.
*Chris
cmorehead13-AquamarineAnswer
@CZ_9645217
*Chris
