Will KEPServerEX Siemens Suite, OPC connectivity suite, Allen Bradley suite support Windows 2022 OS?
  • August 7, 2025
  • 2 replies
  • 637 views
I want to upgrade my windows OS 2016 to 2025. So checking software compatibility for KepServerEX Siemens Suite, OPC connectivity suite, Allen Bradley suite software latest version. kindly advise. Latest version of below software's will support windows 2022 or 2025 OS?
KEPServerEX
(Siemens Suite)
Windows 20166.9.572.0
KEPServerEX(OPC Connectivity Suite)Windows 20166.9.572.0
KEPServerEX(Allen-Bradley Suite)Windows 20166.10.623.0
Best answer by Bhupendra
Please refer to the following article: https://www.ptc.com/en/support/article/CS305196
Windows OS 2025 should work with KepserverEX.
Thanks.
Bhupendra
Bhupendra14-AlexandriteAnswer
Thanks.
Community Moderator
August 14, 2025
Hello @RG_13931778,
It looks like you have a response from a PTC support expert. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
