Jun 10, 2025 1:16 PM UTC
Add spaces in Fil macro (text command)
I try to output my fixture offsets with a fil macro given by KenFarley on an other topic but when i try :
CIMFIL/ON,SET,OFSETL
OFSTYP=POSTF(6,5)
OFSREG=POSTF(7,5)
IF(OFSTYP.EQ.1)THEN
IF(OFSREG.GE.54.AND.OFSREG.LE.59)THEN
$$CURREG=OFSREG
OFSCMD = TEXT/'G90 G',CONVI,OFSREG,2,';'
INSERT/ OFSCMD
ENDIF
ENDIF
CIMFIL/OFF
On my machine file i have :
N0054 ( / SEQUENCE TYPE : PROFILE MILLING);
N0056G90G55;
N0058 G0 Y5.232;
No spaces before G90 and between G90 and G55.
What is the command for output spaces ?
Thanks in advance.
KenFarley
KenFarleyAnswer
Jun 11, 2025 3:03 PM UTC
Here's a thing that you should check that might be doing this nonsense:
Tools->NC Post Processor
Pick the option file for the machine you're trying to fix up.
Click on Operator Messages
Make sure Retain spaces in INSERT statements is checked.
KenFarley
Jun 10, 2025 6:50 PM UTC
When I output text like this to be subsequently output into the code file, I always end the TEXT/ stuff with a
which is comma space single quote dollarsign quote
I think the GPOST interpreter sees that dollarsign as a sort of end-of-line character. It doesn't output it to the file.
Otherwise, I have noticed some weird stuff with spaces in some of the GPOST results. Seems like it is trying to make the code smaller by removing the spaces. I know they are not necessary, the machine strips them all out when I read the programs into memory, but I like them because they make the code infinitely more readable by us poor humans.
See if adding the '$' makes things behave. You might even try ending the line with ';$" since you seem to need a semicolon to end your code lines.
RJ_FR12-AmethystAuthor
Jun 11, 2025 4:58 AM UTC
Thanks for your answer. This is what i tried :
OFSCMD = TEXT/'G90 G',CONVI,OFSREG,2, ' ; ' , ' $ '
No changes, the $ is not print
N0056G90G55;
N0058 G0 Y5.232;
OFSCMD = TEXT/'G90 G',CONVI,OFSREG,2, ' $ '
N0056G90G55$N0058 G0 Y5.232;
N0060 G1 Z-1. F621.;
OFSCMD = TEXT/'G90 G',CONVI,OFSREG,2, ' ; $ '
Jun 11, 2025 2:08 PM UTC
When i pass through a PPRINT commande spaces no longer disappear..
OFSCMD = TEXT/CONVI,OFSREG,2,';$'
TTT = TEXT/ 'G90 G'
INSERT/TTT, OFSCMD
PPRINT/TTT
N0078 ( / SEQUENCE TYPE : PROFILE MILLING);
N0080G90G56;
N0082 (G90 G);
N0084 G0 Y5.232;
