May 17, 2016 5:41 AM UTC
Allow more than 2 digits in the file extension of GPost
Aktually GPost it´s not possibly to create GPost fils with a file extension with more than 2 numbers.
An example for the actuell format is: uncx01.f01
In our company we have more than 99 machines therefore a problem with GPost.
The Idea is to extend the possible numbery, maybe to 4.
I refer to call 12999549
May 17, 2016 1:31 PM UTC
Is the format that hard coded that you cannot change it to something like: HaasVF199.f86?
Which portion is limited to 99 numbers, the uncxXX or the fXX? If either of them allow a rename or both allow 99, then you have 99^2 combinations.
How many machine tools are identical and can use the same post-processor? We used to have 2 or 3 of each machine model and each machine model used the same post, so for 8 machines, we may have had 3 or 4 posts.
