ARC not generated in ZX plane by creo conversational PP of TNC426
- 4 replies
- 4655 views
- Translate All
looking help about postprocessor ..it is a conversational PP of creo for TNC426 Heidenhain. the problem is ARC not generated in ZX plane by creo conversational PP of TNC426 please check pictures.
in where the area of pp I need to investigate to resolve arc issue which is not on XY plane. right now any arc which is on the XY plane work well but as you saw the 3d trajectory path where the arc is on the ZX plane is not generated properly. I change CIRC_INTERPOLATION to POINTS_ONLY in trajectory sequence and the problem was resolved but I prefer to generate the code which is not on the x,y,z points base.
regards
