Nov 5, 2010 6:09 AM UTC
AutoAxis compilation for WF4 and WF5
Hello all,
PTC provides the source code for a utility called AutoAxis, but not the final compiled application that someone can actually use. This utility is extremely helpful when you are using the PRO/NC module. Can someone of you, share this AutoAxis compiled application?
Thank you very much in advance.
Vassilis Anagnostopoulos
SPIDER SA
Industrial Area - Rodotopi
45500 - Ioannina
Greece
