Mar 3, 2011 5:18 PM UTC
{Blank Subject 2011-03-03}
How do I update my g-post for WF4 Pro-man?
Byron Taylor
Coordinator/Programmer
Danfoss Commercial Compressors
One Scroll Drive
Arkadelphia, AR 71923
E-mail: byron.taylor@scrolltech.com
Tel.:870-246-0750
    Mar 3, 2011 5:27 PM UTC
    Which Pro/E version are you using with it?
    Mar 3, 2011 7:00 PM UTC
    Good morning guys. Is there a config option to turn the Workpiece to
    wireframe instead of translucent?
    Thanks.
    Son Nguyen
    Great Plains Mfg.
    108 W. 2nd Street
    Assaria, KS. 67416
    785-667-7763 ext. 3477
    Mar 3, 2011 10:38 PM UTC
    Byron,
    What are you trying to update your G-Post to (Version #)? Every new
    version of Pro/NC swill have a newer version of G-Post. I think WF4 had
    version 6.1 of G-Post.
    Fred Nemecek
    Austin N.C., Inc.
    512/458-1112 x19
    _____
    Mar 3, 2011 11:07 PM UTC
    Good afternoon,
    You can use the "Style" functions in the view manager to set the display options for individual components in your assembly.
    [View], [View Manger]
    [Style] tab
    [New] - create a name
    [Show] tab
    Select display choice, and components to apply it to.
    Dave Ford
    NC Programming Mgr.
    G.W. Lisk Co.
    Clifton Springs, NY 14432
    (315) 462-4381
    P Please consider the environment before printing this email - be green, keep it on the screen!
    Mar 3, 2011 11:20 PM UTC
    That was cool Dave!
    Learned one more thing here... a good one...
    Son, did you consider to submit an enhancement request to allow this in a config.pro option?
    Tks!
    Daniel!
    Mar 4, 2011 12:43 AM UTC
    Since Wildfire 4.0 you can use theView / Display Style / options. You must
    select the wp partbefore using the command otherwise the command is grayed out.
    David Brainsky
    Chula Vista, Ca. 91910
    email: -
    Cell PH:619-253-5137
    Mar 4, 2011 10:58 AM UTC
    There's also this config.pro option: mfg_workpiece_transparency 0.5
    This allows you to control the degree of transparency applied to Workpiece.
    In Reply to David Ford:
    Good afternoon,
    [Style] tab
    [Show] tab
    Dave Ford
    NC Programming Mgr.
    G.W. Lisk Co.
    (315) 462-4381
    Mar 4, 2011 11:52 AM UTC
    I knew about the mfg_workpiece_transparency but did not connect that with Son's request...
    Sorry...
