Apr 21, 2015 8:21 AM UTC
Can any one suggest me steps for getting EMX GENERAL ICON in Creo Mold Cavity..
I am using Creo 3.O and I installed EMX 9.O but i am not able to find EMX Icon/tooldbar in Creo Mold Cavity interferance...
Apr 21, 2015 12:01 PM UTC
Dinesh,
I guess that EMX 9.0 installation contains protk.dat. Edit your config.pro file and add the following option into it.
PROTKDAT full_path_to_EMX_protk.dat
Martin Hanak
Dinesh,
Martin Hanak
dyadav12-AmethystAuthor
Apr 24, 2015 7:36 AM UTC
Thank You Martin.....You always be there to resolve any issue.....Thank You.....
I have another ques... How to add Substitiut Feature(Related Flexible modeling) In Manufactring Interferance....
Apr 24, 2015 7:47 AM UTC
Dinesh,
I am sorry, I do not know Manufacturing mode functionality.
Note:
If you have new question, please open new discussion.
Martin Hanak
Apr 24, 2015 1:51 PM UTC
Dinesh,
when you install emx it adds a config.pro file in the bin directory for each version of pro.
copy all those lines into your regular config.pro. If you do not have the show_dim_sign set
to no it will not make the die set plates correctly-you will see the plates will not look like
they are in proper order. I use a different config.pro for running an emx session than my
normal pro because of this. at least that is how my emx has been working. there is also
a protkdat line in the emx config.pro.
Dick Adelmeyer
Jun 10, 2015 9:53 AM UTC
Thank You...It worked...Thank you and sorry for late
Feb 4, 2016 9:56 AM UTC
Ryan Kelley‌ please add to Expert Moldbase Extension - EMX‌
