Jan 14, 2016 11:07 AM UTC
can windows 10 supports EMX 9.0?
Please tell me can windows 10 supports EMX 9.0
Jan 15, 2016 2:46 AM UTC
Refer to Hardware Notes - Creo 3.0 at http://support.ptc.com/WCMS/files/161492/en/creo3_hw_notes.pdf,  Windows 10 is supported on Creo 3.0 M060 and later. And EMX 9.0 is compatibility with Creo 3.0, so Windows 10 is supported by EMX 9.0.
By the way, install the latest EMX 9.0 M010 is a preference choice.
adeshmukh1-VisitorAuthor
Jan 20, 2016 5:35 AM UTC
I installed EMX 9.0 M010 but it was not run.
Jan 20, 2016 6:14 AM UTC
did you link EMX 9.0 M010 with Creo via protk.dat file ?
MH
Feb 4, 2016 9:02 AM UTC
Ryan Kelley‌: Can you please move this to the Group Expert Moldbase Extension - EMX‌
Feb 4, 2016 9:08 AM UTC
So far EMX 9 is it is not officially tested with Windows 10.
Still there should be no problem with it. You can simply try to install and run it.
Regards
Thomas
Feb 4, 2016 9:23 AM UTC
Hi Thomas,
I tried but it wasn't run.
