Feb 18, 2016 1:37 PM UTC
Chamfering Issue
When I use the automated chamfering sequence I have a problem. If your chamfer angle doesn't match the tool even by a few minutes or seconds of the chamfer angle it won,t cut the chamfer.
When dealing with molds this happens a lot of times for me with drafted surfaces. Here is an example of what I am talking about.
the surface circled in blue has a draft on the side wall so the chamfer will not cut it and throws the error message circled in red.
I think there needs to be a setable angle tolerance for the chamfer sequence because it is just used to break edges and is not a precise cut by any means. If I want a precise angle chamfer I will surface it with a ball end mill.
the work around is to cut it with a trajectory tool path but that is not as easy as just selecting the chamfers with the chamfer sequence.
I was wondering if anyone else has seen this problem before I go to tech support?
Feb 19, 2016 3:13 AM UTC
That has been my experience.
What is needed is an edge break sequence, so you don't need a modeled chamfer of any sort to program edge breaks.
Feb 19, 2016 12:16 PM UTC
I never use auto chamfer tools because it rarely does what I want. I only use trajectory milling and it's quite easy and quick to do by selecting chains.
Feb 19, 2016 1:36 PM UTC
When I encounter this situation, I redefine the chamfer in the model to be "angle x D" (rather than DxD)  and reference a surface that is not drafted.  If you are putting the chamfer in as a 45 between a drafted surface and a flat one, the chamfer tool won't work unless you change the definition of the tool to match the actual angle that the chamfer created.
Feb 19, 2016 6:12 PM UTC
thanks to everyone who replied.
All the replies were correct as far as my question goes they all work.
Raphael,Yes I do use trajectory milling sequence for this situation when the chamfer is really important.But that takes a lot more effort to set up than it really needs to be when the chamfer is already on the part.
Matt, I should not have to go into the part and modify it to cut a simple edge break chamfer if it is already there. again a lot more effort then what is necesary as far as I am concerned when we are looking for quick turn around programs that you just select the geometry and cut.
