May 3, 2016 8:41 PM UTC
changing the size of a mold base
I need your help
The standards of the Mold Base in the Brazil are different of the European suppliers.
How do I create a copy of the complete mold base (eg Futuba) and change the dimensions?
(Example: Distance between columns, distance pin return, etcetera).
You would have any instruction or video material to help me?
Thank you for your help
May 24, 2016 9:20 AM UTC
Hello Mauricio,
Have you ever used the Moldbase Editor in EMX. This is a tool to manipulate the moldbase data that is provided by EMX.
Okay, next Step: What you would like to do is adding a completely new supplier which is maybe called “DME Brazil” maybe? ( I have seen a supplier like this in some other customers configs)
We will copy the existing “d-m-e” data and rename it “d-m-e_brazil”
Now you already have a new supplier showing up in the Moldbase Definition Dialog and you can also manipulate the values of the new supplier with the Moldbase Editor
The values of the suppliers “d-m-e” and “d-m-e_brazil are now completely identical.
It is up to you what you are doing with the “d-m-e brazil” values.
Here is a quick overview of the mold base editor functionalities:
Adding new suppliers is a big project and be careful with the plate values, otherwise it may occur that customers will order plates with wrong sizes.
Have a nice day,
Thomas
