Jun 11, 2013 10:05 PM UTC
Circle centerlines
I've looked on here for some information but with no luck.
I need to be able to add centerlines to arcs when I am making final manufacturing drawings. I know how to get the typical holes, but I need another way to add them to slots for example.
Jun 11, 2013 10:13 PM UTC
You can add a datum point in your extrude sketches and they will create datum axes.
You can also have extruded arcs generate axes by adding the config.pro option: show_axes_for_extr_arcs yes
Jun 13, 2013 4:10 PM UTC
perfect...thanks for the help
Jun 13, 2013 4:11 PM UTC
Whats the best way to reload your config file after you edit it?
