Aug 31, 2011 2:24 PM UTC
Corner Finishing
Has anyone tried out this new sequence? Was this implemented from pro toolmaker? I have found it to be usefull and pretty solid for finish those hard to get areas.
    Sep 9, 2011 2:30 PM UTC
    Nick,
    Sorry it took so long to reply. It has ben a tough week. Trying to get some electrodes cut for our EDM department. One of the electrodes is large so I did the whole thing using the roughing and finishing routines in Pro/Man. I also used the corner routine to pick out some corners.
    I roughed with a 3/8 diameter flat end mill then reroughed with a .0625 ball end mill finished with a 1mm diameter ball mill then did the corners with a ,015 ball mill.
    It worked fairly well other than needing a cray super computer to calculate the tool path. About 850,000 lines of code.
    I am running a Dell Precision Work Station T5500 with a Xeon Processor Windows 7 64 bit with 6 Gigabytes of ram and doing the finishing and corner routines brings it to it's knees. I have the cpu gadget running. it shows 84 percent of all the ram being used and only only 1 of the 4 processors running at about 50 to 80 percent use. So i can definately see that Pro is not multi threaded. The problem I have with the corner routine right now is the tighter you set the tolerance the longer it takes to process the file if it doesn't hang up after about a half hour of processing the ncl file. I like to set it to .0001 but I can't get it to process the file. So right now I have it set to .001 and it seems to work.
    I have not cut it yet to see what the finish looks like. I am a little worried there will be scallops in the corners with the tolerance that loose.
    Aug 31, 2011 3:27 PM UTC
    Nick,
    Never noticed that option... I will have to try it.
    Aug 31, 2011 3:29 PM UTC
    Try these parameters
    Aug 31, 2011 5:46 PM UTC
    Jeez,
    Normal roadblock. The part I tried roughed with a 1/8 .01 radius bull nose end mill. wanted to use corner finish with a .015 diameter ball end mill. Can't select the .125 .010 bullnose end mill as first tool. This sucks I do a lot of cutting with bull nose tools.
