Jun 13, 2014 7:00 AM UTC
Creo 3 - New Volume mill
Looking at a case solution I discovered there should be a new volume mill sequence in creo 3. That's a good news =>https://www.ptc.com/appserver/cs/view/case_solution.jsp?n=CS172911&lang=en
Jun 13, 2014 4:10 PM UTC
Thats great! I would love it if the new volume mill would automatically order the regions by shortest path like drilling, instead of me having to do build cut - order regions.
Who is using the "Stock Model"? It seems like more toolpaths are being geared towards this instead of the "Material Removal Feature".
Jun 13, 2014 5:02 PM UTC
Also a Smart retract that was really truely"Smart" and didn't plow randomly through the stock at rapid when moving from one feature to another would be a nice change.
Jun 18, 2014 6:30 PM UTC
You need to set the traverse feed rate to something less than -1 (rapid) then the 'smart retract will work'
They do not consider the dogleg that happens with uncoordinated moves at rapid. If you notice, all moves in NC check (inside CREO) are coordinated.
IMO, they should have a dialog that warns you if you set smart retract, you cannot set traverse speed to rapid (and vice-versa)
Chris Gosnell
