Nov 30, 2018 6:55 PM UTC
Creo 5.0 HSM Rough
Having issues with HSM Rough, Parameters are set up for Rough Only, Constant Load, Step Over .03 , Max Step Depth .625
Issue with this is it still wants to do a full retract when the tool path starts to work in corners. Instead of doing a small tool lift.
Any suggestions or solution's would be appreciated.
Dec 3, 2018 3:12 PM UTC
Also set
MIN_RETRACT_DISTANCE 8
8 inch  or some other large number
Also set
shaun11-VisitorAuthor
Dec 3, 2018 7:00 PM UTC
That seemed to solve my issue, Thank you!
Dec 5, 2018 6:42 PM UTC
I am using 5020 and cannot find this option in my parameters.
Where is it ?
