Dec 4, 2021 8:37 PM UTC
Creo 8: Thread mill bug?
Thread milling seems broken in Creo 8.  I used a template that worked fine in Creo 7, but now in Creo 8, the lead-in radius is the wrong direction.  It's still tangent, but the wrong way.  I can't get it to change and have to switch to a radial entry so that there is no radius.  Is this a bug, or am I doing it wrong?
Daniel_EAnswer
May 29, 2022 6:32 AM UTC
This turned out to be a problem with the part model.  I used thread milling on many other parts since then without issue.  So I went back to that part and re-modeled the feature, and the thread milling worked without issue.  The original file was imported from another CAD software, so maybe that caused some issue.  Anyway, doesn't seem to be a bug after all.
Dec 5, 2021 3:33 PM UTC
Daniel_E12-AmethystAuthor
Dec 5, 2021 8:53 PM UTC
Thanks Vladimir!  I didn't know such a thing existed.
Dec 6, 2021 8:41 AM UTC
You're welcome.
