Creo CNC Program and post processor code generating capabilities
Currently we are dealing with 2 machines at client site . Now how can we know that if code generated by Creo Machining extension can be directly integrated with these machines or not. If we require to develop post processsor then how much it will cost to develop new post procesor.
Is there some list of machines and manufacturers which show direct integration or post processor requirement? I am from sales back ground so i need basic info.
  1. 1. FBE-2600
http://www.eumach.com/company-all.htm
  1. 2. CNC-EB 800L, JS EDM
http://www.jsedm.com/products_2.htm
Creo generates *.tap files, then you need a posprocessor to "translate" for you machines.
Here's a list of several post processor provided by PTC => http://support.ptc.com/cs/fr_25/howto/ncgp4905/ncgp4905_f.htm
bhussain1-VisitorAuthor
Hi
thanks for the help and prompt reply.
Please explain how to select right processor for the specific machine?
Please also elaborate that can we use PTC Creo Built in processor for this as well?
I'm sorry but I won't be able to answer as I don't know. I'll let the experts of this forum answer !
