Aug 11, 2016 2:45 AM UTC
CREO DETAILING TEMPLATES
Hello Guys,
I've been working in a small scale industry for Past 2years Here i don't follow any Drawing standards. I do Detail the drawings with necessary dimensions for manufacturing thats it.
But In Interview They are asking about a Drawing standards whether i Follow ISO or ASME standards when I say I don't adhere any standards I get rejected.
Can you please tell me how to Detailing drawings according to any standards It would me helpful if you guys can provide me with any of your standard Templates of A4 and A3 Sizes
I can learn to make use of it.
Thank you
Bob
StephenW
StephenWAnswer
Aug 11, 2016 1:18 PM UTC
The template is not the standard.
You need ASME y14.100 and asme y14.5 and/or ISO 128 and ISO 129.
Google those to get an idea of what the standards look like.
StephenW
StephenW23-Emerald IIIAnswer
Aug 11, 2016 2:26 PM UTC
Thank you for the reply I will study the standards.
Can i get a A4 Sample template of yours it would be much helpful.
Babu
Aug 11, 2016 1:34 PM UTC
To say that you are not working to any standards not true.
By using this software, you are using standards, you are just not "aware".
You may need to customize to fit the needs of your company and customers, but the standards allow for this.
In the ASME world, the lead document is ASME Y14.100 and this will be broken down into sub categories such as:
  Y14.1 Decimal Inch Drawing sheet size and format, Y14.1M Metric Drawing sheet size and format
  Y14.2 Line conventions and lettering
  Y14.3 Multi-view and Sectional view drawings
  Y14.5 Geometric dimensioning and tolerancing
and so on....
In the ISO world
  128  Technical drawings - general principles of presentations
  129  technical drawings - dimensioning - general principles
  1101 parts I and II, technical drawings, geometrical tolerancing
and the list is long....
Some education on standardization should be high on the priority list.
Aug 11, 2016 2:25 PM UTC
Babu
Aug 11, 2016 3:17 PM UTC
You can find templates in the default proe load directory
c:/program files/PTC/Creo 2.0/Common Files/<build>/templates
This contains some start parts along with various .drw templates.
You can create your own "format" or .frm by saving one of the templates as a .frm file type or modifying an existing.
do some searching on the site for creating templates or drawing formats for more detailed help
