Nov 20, 2025 6:20 PM UTC
CREO FLOATING RUN OVER VIRTUAL SERVER
Please,,
clarify to me
Is possible i,
and run locally Creo Floating (as client)?
Thank you,
Pedro.
Nov 20, 2025 6:28 PM UTC
A better explanation of what you are trying to do may help to get e better answer.
If you mean can you load Creo on a server and have it executed locallly, that does work. I did it at my last company for 15 years. You just need to set some environment variables for the creoagent and the manifest folders. I used a batch file on the user's desktop to launch Creo. This file would set the environment variables needed, copy some config.pro files and then start Creo. Made upgrades to a new version very painless, install the new version, change the launch script and the users had the new version the next time they launched the script.
Community Moderator
Dec 28, 2025 6:09 PM UTC
Hi @phernández,
Anurag
