Apr 23, 2025 3:22 PM UTC
Creo Manufacturing- Use Reference Model instead of All Models
I am using Creo Parametric Release 10.0 and Datecode10.0.5.0
For hole making manufacturing sequences, for whatever reason ours defaults to all models instead of reference model. To be more clear, I'm referring to when you click on the Mill tab>Holemaking Cycles>Standard (or whatever floats your boat)>References>Details>Options...the dropdown here defaults to All Models, and I am wanting it to default to reference models, since i am setting my reference model. As you can imagine, when we go to make a new program based off of an existing one, and we remove a fixture component, it causes manufacturing sequences to fail because they are being tied to these random models instead of just to the reference model.
I have searched config.pro options and the knowledge database and I'm finding nothing that can point me in the right direction on whether the default to this can be set when creating new sequences. If this does not already exist, can this be added as a config.pro option?
Mahesh_Sharma
22-Sapphire I
Apr 25, 2025 1:48 PM UTC
Hi @JNunner
As of now there is no option to change to default. However this can be an enhancement subject.
Kindly submit an idea Product Ideas @ PTC Community
Thanks.
Mahesh_Sharma
22-Sapphire I
Hi @JNunner
Thanks.
