7-Bedrock
Jul 11, 2025 6:16 PM UTC
Creo NC, "can't access list of available post processors, exiting"
Hello, I receive the errror message listed in subject line when trying to post an NC file.  I have set the "ncpost_type" setting in the configuration editor previously.  I am using Creo 9.   Any help is appreciated.
7-Bedrock
Jul 17, 2025 7:24 PM UTC
My gpostpp_dir setting was indeed not pointing to the right directory.  It turned out that the gpost directory was missing entirely.  After reinstalling Creo and setting the gpostpp, all seems to work now.  Thank you.
KenFarley
Jul 11, 2025 7:35 PM UTC
I don't know what other settings you have in your config.pro file, but these are my settings.
! Category : Manufacturing
drilling_ui_end_opt_default reference
drilling_ui_start_opt_default reference
enable_classic_nc_steps yes
enable_classic_cutline yes
enable_classic_strghtcut_srfml yes
gpostpp_dir c:\ptc\Gpost
mfg_assign_param_formula no
mfg_ijk_num_digits 5
mfg_xyz_num_digits 7
mfg_setup_dir c:\ptc\MfgParams
mfg_solid_tool_display yes
moduleworks_setup_file c:\ptc\DefaultFiles\moduleworks-settings.xml
!nccheck_type moduleworks
nccheck_type nccheck
ncl_file_extension ncl
ncpost_type gpost
pro_mf_cl_dir c:\ptc\NCFiles
pro_mf_param_dir c:\ptc\MfgParams
pro_mf_tape_dir c:\ptc\NCFiles
pro_mf_tprm_dir c:\ptc\MfgParams\Tools
store_tool_path_file no
If I had to guess I'd say you are either not specifying a directory for the gpostpp_dir setting, or the location specified does not exist, or the directory specified is unreadable or empty. Maybe your setting points to a previous Creo installation directory that no longer exists?
There seem to be a bunch of "default" posts (Located in C:\Program Files\PTC\Creo 9.0.9.0\Common Files\x86e_win64\gpost on my machine) provided in the Creo installation. I don't know if they are any good - I've had my own locally stored list of posts for decades.
JK_137904807-BedrockAuthorAnswer
7-Bedrock
