7-Bedrock
Aug 20, 2022 11:15 AM UTC
CREO7/NC How to set Helical Pitch for Cutline Milling when Milling a Hole
Hello, All
When I use Cutline Milling to mill  a hole, I use Type_Helical , however, I found that I can not set Helical Pitch for Helical milling.
Can anyone help me on this issue?
bmullerAnswer
Aug 25, 2022 2:18 PM UTC
Have you tried adjusting STEP_OVER to a smaller value?
bmuller14-AlexandriteAnswer
7-Bedrock
Aug 26, 2022 9:56 AM UTC
you are absolutely right, the pitch is controlled by STEP_OVER.
thanks for your help!
