Jan 26, 2010 7:43 PM UTC
Curve from points.
I am trying to construct a curve based upon about 600 data points (2D) from a CMM. They are an a CSV file now. Any techniques of which anyone is aware? These are from the sphere center, so I'll just have to construct an offset curve to achieve the correct spline. I don't really ever work with imported data, so this is all Greek to me!
Jan 26, 2010 7:53 PM UTC
Use Insert, Model Datum, Point, Offset Coordinate System,
Select your coordinate system, spherical, then import.
This will read in all of the points from a csv file.
Then Insert, Model Datum, Curve.
Thru Points and Done
Then Spline, Whole Array and select your point.
That should do it. Feel free to call if you have any questions.
Bob Frindt
Sr. Designer
Parker Hannifin Corporation
Parker Aerospace
Gas Turbine Fuel Systems Division
9200 Tyler Boulevard
Mentor, OH 44060 USA
direct (440) 954-8159
cell: (216) 990-8711
fax: (440) 954-8111
www.parker.com
Peter Brown <->
01/26/2010 01:43 PM
Please respond to
Peter Brown <->
To
cc
Subject
[proecad] - Curve from points.
Site Links: View post online View mailing list online Send new post
via email Manage your subscription Use of this email content is
governed by the terms of service at:
Jan 26, 2010 7:54 PM UTC
I should have mentioned that I believe that the csv file has to have a
.txt extension.
Bob Frindt
Sr. Designer
Parker Aerospace
fax: (440) 954-8111
www.parker.com
Peter Brown <->
01/26/2010 01:43 PM
Please respond to
Peter Brown <->
To
cc
Subject
