Apr 29, 2015 2:28 PM UTC
Custom Drill Cycles
Need help setting up a custom drill cycle for thru spindle coolant drills in a VMC. I will be spotting the holes 2xD with short drill first. After the holes are spotted this is what I am looking to do:
Enter hole at a lower rpm (around 300rpm)
Turn TSC ON
Ramp spindle speed to desired RPM
Drill Hole
Return to origanal starting point
Ramp RPM back down
Turn TSC OFF
go to next hole
Custom drill cycle seem like the way to go to do this just not familar with them and the daocumentation is lacking to say the least. We drill anywhere from 100 to over a thousand holes in one block. I have been able to use normal drill cycles for the shorter drill but when using 15D or 20 D drills they will snap if the tip is not supported in the hole when ramping up to proper spindle RPM. I might want to try a different variation where the TSC coolant stays on the entire time instead of on/off for every hole. I will say that I do not program everyday but trying to utilize the machine and tooling to their potential. Thank you for any help.
Kevin
2-Explorer
Apr 30, 2015 10:25 AM UTC
Can you explain what you mean with coolant on/off for every hole?
Usually, when I set the parameter COOLANT_OPTION to ON in a drilling sequence, coolant switches on and stays on hole by hole and hole set by hole set for the whole sequence. Are you using multiple sequences and want coolant stay on between them?
Apart from this, have you considered adding coolant ON and OFF by simply adding CL Command relative to toolpath? It might be easier to do than creating a custom cycle just for the purpose of switching coolant on and off.
kpratt1-VisitorAuthor
Apr 30, 2015 3:08 PM UTC
The drill manufacturer reccommended turning the thru spindle coolant on after the drill has entered the pilot hole. From what testing I have done so far I really don't think it would matter, I would actually prefer to leave the coolant on throughtout the entire drill cycle. My main concern is entering the pilot hole at the reduced spindle RPM and then ramping up to the proper drill RPM. These longer drills snap like a twig if the tip is not supported in the pilot hole and drills are not cheap.
