May 19, 2017 5:24 PM UTC
Cutline producing flats in Circle Interpolation - Creo 2.0 M240
I recently updated Creo 2.0 from M090 to M240 and noticed on a couple of occasions that I am getting some flats in the tool path when using Cutline to Circle Interpolate a hole.  I have seen this before and can sometimes fix it by loosening the tolerance, but it has been a long time since I've seen it and I do a fair amount of this.
Is this anyone else has noticed or am I alone on this one?
Matt
May 19, 2017 5:47 PM UTC
why did you replaced M090 by M240 ? If you did not do it for serious reasons, that I suggest you to return back to M090.
MH
razmosis14-AlexandriteAuthor
May 19, 2017 7:02 PM UTC
We were issued new computers.  IT Dept. had initially loaded M020 and I noticed that things I had just programmed wouldn't work for me.  That's when I noticed the date code change.  I then discussed it with the other users and we knew we had to at least get back to M090.  So, we were given the choice between M090 or the latest M240, and we went with M240.  Going back to M090 would likely cause some issues with what we've now created in M240 and I know that some (here) are fond of the Moduleworks we now have.
We also got 4.0 M010, but haven't gotten the licenses to work yet.  It hasn't been a big priority.
Matt
