Dec 8, 2016 8:18 PM UTC
Does Production Machining give .tap and g-code functionality?
Will the production machining option in Creo give me the ability to post process my models in manufacturing mode to a .tap file. Will it also post process to g-code and does it come with the basic drivers to post to g-code?
Dec 8, 2016 8:51 PM UTC
Dustin,
Yes the production machining has the ability to post process files to G Code using G Post from Austin NC. All the manufacturing  modules have the ability except for expert machinist as I found out a while ago.
There is a large assortment of pre built posts in the support portal that you can use or build your own using them as starting points.
Steve L.
Dustin,
Steve L.
dmayfield1-VisitorAuthor
Dec 8, 2016 8:56 PM UTC
The large assortment of pre-built posts are located here: http://support.ptc.com/cs/cs_27/howto/ncgp4905/ncgp4905.htm correct?
Thanks!
Dec 8, 2016 8:59 PM UTC
Those are the ones. can't you find what you are looking for?
Dec 8, 2016 9:12 PM UTC
Those are all fine, was just checking if that was the full library! Thanks so much
