Nov 6, 2013 11:42 AM UTC
Draft Analysis
Okay.....I have to ask this again. Have we totally lost the ability to specify a two color draft analysis?
If we have, note to PTC Developers: A five color draft angle range is CRAPPY! There is no way actual plastic partor casting designers were consulted on that.
If we do still have this essential ability, please enlighten me on how to do it. I cannot change 5 to 2 in the range box nor can I effect change anywhere else that I can determine.
DeanLong1-VisitorAuthor
Nov 7, 2013 6:20 PM UTC
I did know that Bernie......thanks. BUT with this particular model (approaching 2500 features) wireframe gets super slow while spinning. I know it's a work around. Thanks.
Nov 7, 2013 7:09 PM UTC
No worries. Believe me, (like all the rest of us on this forum) I'm all
to familiar with the frustration that comes along with converting into
Creo2.
Nov 7, 2013 10:40 PM UTC
I don't know about your install, but with my install of CEP5.0 and CREO 1 Pro-Foundation/Advantage, I need TDO option to get Silhouette curves. (and a bunch of other things)
Christopher F. Gosnell
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
Nov 8, 2013 2:02 PM UTC
All,
I have received a couple of questions asking how to save and implement the
WF style Color Scheme file... So, I thought I would just share to the
group. Here Goes...
While in Draft Check, At the bottom of the "Color Scale" window...
Hit the Arrow "down" that expands the color scale settings
Click the left "rainbow" icon (this is the old WF colors)
Change the settings number to 7
at the bottom of the window, hit the "Save" icon, and save the
"Color_scheme.txt" file to your user directory.
Then, add this line to your config.pro
geometry_analysis_color_scheme j:\PTC_User\bernie\Creo2\color_scheme.txt
(Be sure to type in your proper path with file name, instead of my
J:\etc\etc)
Good Luck
Bernie
Owner / Designer / Builder
www.GrumanCreations.com
On Thu, Nov 7, 2013 at 12:09 PM, Bernie Gruman
> Creo2.
