TTP_1016763311-Garnet4 years agoSep 19, 2022 12:27 PM UTCQuestionEMX 13 component editor0 replies1119 viewsTranslate AllDearI would like to add some part in library component.But the problem is that parameter wont rewrite. ( ord_number)The parameter stays the same as in the part in library. (empty)How to fix this that parameter will update from library data file?Do i need to have part in library with any parameter Mold & Moldbase Machining
