Apr 3, 2019 10:06 AM UTC
emx_comp.rel file
what is the use of emx_comp.rel file?
Please provide some documentation for the same?
Apr 5, 2019 1:28 PM UTC
Hello sammy,
you can download our tutorial and you will find a section which describes the emx_comp.rel file.
Basically, you can use the emx_comp.rel file to write relations to all components that are assemble with EMX.
https://community.ptc.com/t5/Manufacturing/Expert-Moldbase-Extension-10-Tutorial-for-download/m-p/604966#M4438
sammy19941-VisitorAuthor
Apr 5, 2019 1:54 PM UTC
Thank you for your response!!
Can you please tell me if it is possible to use that file to add some data to the BOM.
For ex: specifying the material parameter of screw in the .rel file so that it gets updated in the BOM.
I tried doing it but was unsuccessful
Jun 18, 2019 5:33 AM UTC
if you set up a relation that fills the content of a defined EMX Parameter, the parameter value will be visible in the BOM.
Kind Regards
