Nov 6, 2016 5:58 AM UTC
end of nc sequence
Dear all ,
At end of Sequence I require following command "G0G80G90Z100.0M05M09" , Currently for every sequence I add CL command  INSERT/G0G80G90Z100.0M05M09.
Can this be done in post processor , like how we add for start and end program using "Start/End of Program".
Can you please suggest best method to handle the End of Nc sequence
KenFarley
KenFarleyAnswer
Nov 9, 2016 6:16 PM UTC
So, I guess the answer to my question is that you are actually trying to output some special code at the next tool change. The reason I asked is because in the manufacturing module, a "sequence" is one particular defined set of motions. I could have a number of consecutive sequences right after each other, like "cut outside shape", then "cut inside shape", etc. which use the same tool. In the generated CL code, I won't see a SPINDL / OFF until the second "sequence" is done.
For what you are doing, it seems like responding to the "SPINDL / OFF"  via
CIMFIL/ ON, SPINDL
(check if it's an "off" command, process as usual otherwise)
CIMFIL/ OFF
is the way to go. It's far better than having to add CL Commands to your sequences to take care of it, because those tend to be something I'd forget, eventually.
KenFarley
Nov 8, 2016 1:36 PM UTC
By "at end of sequence" do you mean "at next tool change"?
I'd start by looking at all the options available in the NC Post Processor Java application. If you don't find anything there that addresses your specific needs, you will need to delve into the FIL code world to handle the outputting of your NC code.
pesau-21-VisitorAuthor
Nov 8, 2016 5:51 PM UTC
I am trapping the spindle stop and writing the end sequence using the FIL code is there any other simple method to capture the END OF SEQUENCE.
KenFarley
KenFarley21-Topaz IIAnswer
CIMFIL/ ON, SPINDL
CIMFIL/ OFF
