Nov 29, 2021 2:01 PM UTC
EZ Tolerance Analysis module fatal error when started
I am using Creo Parametric 6.0 6.0.6.0
When launching the module EZ Tolerance Analysis, it results in a fatal error.
Here are the errors that I faced
Fatal error encountered. A traceback has been written to C:\PTC\start_creo\traceback.log
Please send it to Technical Support.
Nov 29, 2021 5:51 PM UTC
You need to open a new technical support "Case" (and send this log to them), here: : https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
