8-Gravel
Nov 13, 2020 5:36 PM UTC
Facing Direction
I am looking to change the direction the tool moves so that it moves down the face of the part with each pass.
It wants to cut in the z direction.  I would like it to cut in the x direction.
I believe this yellow arrow has something to do with it.  Is there a way to rotate this arrow?
slolliAnswer
Nov 30, 2020 7:51 PM UTC
Hi, in the parameters for the Face milling toolpath, change the CUT_ANGLE parameter from 0 to 90.
slolli10-MarbleAnswer
MDrake8-GravelAuthor
8-Gravel
Nov 30, 2020 7:58 PM UTC
Thank you!!
