Oct 29, 2011 10:44 AM UTC
Fill routines for Fixture Offset and Tool length offset
Dear Pro/Gurus I need your expert help.
I need two fill routines,
First to add the line G0 X0 Y0 C0 B0 after the fixture offset (set / ofsetl,
54)
and the second to read the tool number of Loadtl / 1
and put it along with Spindle command with the format G43.4 H1 S...M3
Before
T1
M6
G54
S1100M3
G1G94X241.131Y0.0Z-66.0C0.0F9999B90.0
X162.0
X158.0F100
After
T1
M6
G54
G0X0Y0C0B0
G43.4H1S1100M3
X162.0
X158.0F100
T.I.A
Georgios Lambouras
C.N.C programmer
    Oct 30, 2011 8:53 AM UTC
    Gpost forces tool length offset number (G43.4) along with (H) register
    to be output with the next Z value.
    Is there a fill routine that reads the tool number (LOADTLl / 1) put it
    together with spindle command
    composing the following format?
    G43.4 H1 S1100 M3
    Or it can be output right after the spindle command.
    S1100 M3
    G43.4 H1
    Before
    T1
    M6
    G091 G28 Z0.0
    G090
    G54
    G0X0.0Y0.0C0.0B0.0
    S1100M3
    G1G94G43.4X241.131Y0.0Z-66.0C0.0F9999H1M8B90.0
    X162.0
    X158.0F100
    X241.131F9999
    After
    T1
    M6
    G091 G28 Z0.0
    G090
    G54
    G0X0.0Y0.0C0.0B0.0
    G43.4H1S1100M3
    G1G94X241.131Y0.0Z-66.0C0.0F9999M8B90.0
    X162.0
    X158.0F100
    X241.131F9999
    NCL FILE
    $$* Pro/CLfile
    $$-> MFGNO / T15_MFG
    PARTNO / T15_MFG
    $$-> FEATNO / 148
    MACHIN / UNCX01, 32
    $$-> CUTCOM_GEOMETRY_TYPE / OUTPUT_ON_CENTER
    UNITS / MM
    LOADTL / 1 $$-> CENTER DRILL 6MM 90DEG
    $$-> CUTTER / 6.000000
    SET / OFSETL, 54
    $$-> CSYS / 1.0000000000, 0.0000000000, 0.0000000000, 0.0000000000, $
    0.0000000000, 1.0000000000, 0.0000000000, 0.0000000000, $
    0.0000000000, 0.0000000000, 1.0000000000, 0.0000000000
    MULTAX / ON
    INSERT/G0 X0.0 Y0.0 C0.0 B0.0$
    SPINDL / RPM, 1100.000000, CLW
    COOLNT / ON
    FEDRAT / 9999.000000, MMPM
    GOTO / 241.1307, 0.0000, -66.0000, $
    1.00000000, 0.00000000, 0.00000000
    GOTO / 162.0000, 0.0000, -66.0000, $
    FEDRAT / 100.000000, MMPM
    GOTO / 158.0000, 0.0000, -66.0000, $
    T.I.A
    Georgios Lambouras
    C.N.C programmer
    _____
