May 23, 2018 4:46 PM UTC
flexible parameter preservation
Flexible parameter preservation not retained in cabling manufacturing flat assembly.
When applying parameters (dimensions) to a flexible part in a cable assembly the part reverts back to the original state when flatting the cable assembly in manufacturing.  Is there a way to preserve the flexible part parameters as in the cable assembly when flattening the assembly.
    Jun 4, 2019 2:07 PM UTC
    I have the same issue, did you ever get an answer?
