Feb 8, 2012 9:08 PM UTC
Generating an X,Y,Z point table from a Pattern of Points
All,
I need to create a pattern of points through a closed loop datum curve. I already have the curve, but my customer now wants a point file for creating a waterjet toolpath file.
So if I create a pattern of points along a curve or boundary edge of a sheetmetal part, then:
  1. How do I extract the X, Y, Z coordinates from the pattern and list these values in a table?
  2. How do I extract the table to MS Excel?
TIA.
Sincerely,
Neal Rosenblum
Geometrix Engineering, Inc.
201 N. 13th Avenue
Hollywood, FL 33019
Ph: 954-920-2049
Fax: 954-920-9574
Cell: 954-649-9399
neal@geometrixeng.c
Feb 9, 2012 9:20 AM UTC
Hi Neal.
The function you need is "hole table" - to be found in Tools-Menu in WF4 or on left side of Table-Tab in WF5. Always drawing mode.
Either way
- create a drawing of your model - one view at least.
- insert a hole table using datum points - select corresponding coordinatesystem on drawing during creation (z must be normal to screen, x and y horizontal/vertical - so maybe you have to create an extra coordinate system)
- choose corner of table
The resulting table can be saved as CSV-file and then imported to Excel.
If you need more information in detail search for either "hole chart" or "hole table" and "export table" in Pro/E-help.
Hope this works for you
Matthias.
-------- Original-Nachricht --------
Sep 10, 2018 5:58 PM UTC
Thanks for posting this.
Barry
Feb 9, 2012 1:37 PM UTC
Thank you Mattias and David.
I had tried to do what you suggested MANY times with no success. I then realized that the points,
Thank you.
Sincerely,
Neal Rosenblum
201 N. 13th Avenue
Hollywood, FL 33019
Ph: 954-920-2049
Fax: 954-920-9574
Cell: 954-649-9399
neal@geometrixeng.c
