Help with Drilling in Pro/NC????
- 7 replies
- 4340 views
- Translate All
Can someone help with a drilling issue if you have time? I attached a file containing the result of what i want to drill. Problem is that not all the holes are drillable without to much manual labor. I was thinking someone might know a way to convert the holes that aren't recongized by the software as holes or maybe have a way to convert them to holes so that the software can read them. I know some other CAM softwares will convert. I hope someone can help otherwise i may need to look at different softwares which i'd rather not do. Hope this makes sence, just want to see waht you guys think based on the actual model.
Jeff
