Dec 23, 2019 9:58 AM UTC
how to combine several operations into single NC file ?
How to combine several operations into single NC file? (For ex. Facing, End and Volume milling in one NC file)
Mahesh_Sharma
22-Sapphire I
Dec 23, 2019 12:26 PM UTC
@Shankar_DT
You can use "Save CL File for set" available under "Save a CL File" menu.
Save CL File for set > Create > Set Name > Select required sequences > Done Sel > Output > Select Set  > File > Done.
I hope this will help.
Dec 27, 2019 3:54 AM UTC
thanks @Mahesh_Sharma Mahesh
