Feb 15, 2016 12:48 PM UTC
How to generate CNC code for a simple milling operation?
I'm trying to generate a G code in CREO 2.0, but the didn't work. The manufacturing have give me just the number senquence of deslocament, but not the G code of operation. Someone new what happened? How I can do it works? Thanks.
Feb 15, 2016 1:43 PM UTC
Hi, to do this you need to have a post processor. Do you have one ?
Feb 17, 2016 2:20 PM UTC
Hi Giovanna,
You need to select a post processor while you save the cl file.
As Rapha said, the G codes are different for different post processors, try the following step, it should be easy.
1. Select "save a cl file"
2. Select "operation / nc sequence"
3. Then select the respective operation / sequence you want to extract G codes for
4. Select "file > (tick MCD file) > select done > specify a name for the cl file > select "done" again under 'PP options'
5. you will be shown a list of pre saved post processors.
6. Select the one ending with .P15 (that is what I use for my machine)
7. Open the file with .tap extension using notepad.
8. Check whether it suits your machine by running simulations.
NOTE: post processors are different for different machines, if you want to learn to make your own post processor , please ask for further help from the experts at the forum.
